What if you see Check Engine light on your Car
Check engine light appears on your car's dashboard, and looks something like this:
A healthy vehicle is not expected to show this light. If this has appeared during/after your installation of NexCruise, follow these steps to fix it.
Reason
The VCU expects a certain signal on the Accelerator pedal input. Normally it is given directly by the sensor within the A-pedal. But during installation of NexCruise, when we disconnect the A-pedal, if the signal is missing for any reason, the VCU logs it as an error and the car shows the "Check Engine" light.
These are the flags that are normally raised : A-pedal undervoltage on pin 1, A-pedal undervoltage on pin 2.
Observations
Turn ON the car and see the engine RPM.
Is it above 1000RPM?
Yes? It is still not getting the needed A-pedal signal. See first fix in Rectifications list below.
No? This is good news. Proceed to check the next point.
When you press the A-pedal, is the car responding to that?
Yes? Is the RPM also below 1000? Things are okay, the engine light has come due to an earlier event (most likely you disconnected the A-pedal when the car was ON, read below for more information) but the reason is already rectified. The engine light will also disappear after a few start-stops of the car. You can continue driving the car, things are ok now, and the engine light will fix itself shortly.
No? It is still not getting the needed A-pedal signal. See first fix in Rectifications list below.
Rectifications
The VCU cable isn't securely connected
Did it "click" in place?
Verify it again. And connect the NexCruise bypass connector and see that the physical connectors are connected perfectly. It should respond properly with the bypass connector.
Refer here to see how to connect the bypass connector.
Once it works with the bypass connector, connect NexCruise again and see if this solved the problem.
The A-pedal cable was disconnected when the car was ON
Sometimes, we dont wait long enough for VCU to switch off internally before touching the A-pedal connection. This triggers the A-pedal flag. However if everything else is correct, although the errors will be logged, but its is harmless and check engine light will disappear in a short duration.
A failsafe but lengthy idea is, to always disconnect the car's -ve terminal of the battery before installing or removing the NexCruise. That will make sure you never trigger this particular reason.
The firmware in your NexCruise is of a different car
You can verify this from the NexCruise app. Go to Menu > About and see the car for which the NexCruise is configured. It must match the car in which it is installed. Call our customer support if there is a mismatch.
    • First drive with NexCruise!
      Prior to drive When you are ready for the first drive, do the following in sequence. No shortcuts! Before proceeding, ensure that the batteries are inserted in your NexCruise's wireless dial. Do not crank the car immediately when you are starting the ...
    • Checking firmware version of NexCruise
      Introduction The software that powers your NexCruise is called "Firmware", which gets updated from time-to-time via the so-called OTA (over-the-air) updates. OTA updates bring new features, enhancements, and bugfixes to your NexCruise. The Version ...
    • My car's RPM is 1200-1500, my accelerator is not responding, and engine check light is ON
      Root cause When A-pedal signal is missing, the car's engine revvs up to 1200+, and this behaviour happens. Possible reasons Car turned on when NexCruise is off OBD connector might be disconnected and car is turned on. Solution If OBD cable needs to ...
    • Connecting NexCruise to your car
      This is an article in series with the Installation Process of NexCruise. Be sure to start from the start! First article:<TBD>Previous article: <TBD> Next article: <TBD> NexCruise Installation We will remove the cable from the car's pedal (by pressing ...
    • Understanding the NexCruise dial
      TBD: Video demo of these features Dial keys assignment By turning on the ignition of the car, we will see in the Status LED bar that the blue light will come on in the state. When the speed of the car will be 5 Kmph or more, then the state light will ...
