When cruising with NexCruise, the actual speed varies by a few points from the set speed. Is this ok?
Yes. It's the way the NexCruise is designed to work.
When cruise control is engaged, it is normal for NexCruise to vary the actual speed a few kmph around the setpoint.
You might notice it when the car is climbing a flyover. Or if there is a reasonable "gradient" in the road that you're driving on.
In these conditions, the device doesn't aim for holding the speed smack on setpoint. Instead, it keeps a "breathing margin", about 2-3 kmph around the setpoint.
Keeping the behaviour this way helps us keep the NexCruise a universal device, so it can be migrated to any other car too. And then, keeping it too stiff would make it go harder on fuel consumption, and feel less "organic". It would make the cruise resume speed more aggressive too.
In real world, it delivers you all the benefits of cruise control, ease of driving, huge savings on fuel!
If however, you find that your device is deviating too much from the set speed, (say, more than 5kmph), do get in touch with our tech team, and we will sort it out for you.
    • 5. First drive with NexCruise!
      ? Prior to Drive When you're ready for your first drive with NexCruise installed, follow these steps exactly in sequence—no shortcuts! Prepare the Wireless Dial ensure that the batteries are inserted in your NexCruise's wireless dial. Do not crank ...
    • 1. Checking firmware version of NexCruise
      Introduction The software that powers your NexCruise is called "Firmware", which gets updated from time-to-time via the so-called OTA (over-the-air) updates. OTA updates bring new features, enhancements, and bugfixes to your NexCruise. Each firmware ...
    • 1.NexCruise Installation: Diagnosing and Solving Check Engine Light Problems
      ? Check Engine Light During NexCruise Installation ?Introduction The Check Engine Light may appear on your dashboard during or after installing NexCruise. It looks something like this: A healthy vehicle is not expected to show this light. If this ...
    • 5. Using the NexCruise Steering mount dial
      ?Dial keys assignment Dial key Button Location Function Photo Cruise control Centre Button Cruise on Cruise off Cruise resume(Hold 2 sec) Speed limit Left side button Speed limit on speed limit off Eco mode Top button Eco mode on City mode Right ...
    • 2.My car isn't picking up speed. What's wrong?
      Basic Checks When Car Not Picking Up Speed Scenario 1 Speed Limit Set Too Low Diagnosis Have you enabled the speed limit in the Car.Os app? Check if it’s set to a very low Speed limit. Solution Raise or disable the speed limit in the app. Scenario 2 ...
