2.Dos and donts for installation
When you install, ensure the following:
✅ Dos for NexCruise Installation
  • the car is completely powered off before starting the installation.
  • ensure the bypass switch is easily accessible.
  • Do use gentle curves when routing cables — avoid sharp bends.
  • Do secure all cables using cable ties, especially around moving parts.
  • Do leave enough slack near connectors to prevent strain on pins.
  • Do double-check port labels (NC-PORT A, B, C, etc.) before plugging in.
  • Do perform a functionality test after installation: check for power lights and system indicators.
  • Do place the NexCruise unit in a dry,moving free area inside the vehicle cabin.
❌ Don’ts for NexCruise Installation
  • Don’t route cables near sharp edges, hot surfaces, or moving parts.
  • Don’t connect anything to NC-PORT D unless instructed (used only for certain cars needing a brake sensor).
  • Don’t overtighten cable ties — this can damage wires, especially near the connectors.
  • Don’t plug in the NexCruise power (OBD) until all other cables are connected.
Info
This is an article in a series with the Topic "Installation of NexCruise".
