Diagnosis
- Have you enabled the speed limit in the Car.Os app?
- Check if it’s set to a very low Speed limit.
Solution
Raise or disable the speed limit in the app.
Scenario 2
Is NexCruise Power ON?
Diagnosis and solution
Check if the 12V and SYS LED lights up when the Car ON in ignition mode.If not, the unit may not be powered on.check next issue.
Scenario 3
