First drive with NexCruise!
Prior to drive
When you are ready for the first drive, do the following in sequence. No shortcuts!
Before proceeding, ensure that the batteries are inserted in your NexCruise's wireless dial.
Do not crank the car immediately when you are starting the car with NexCruise installed for the very first time! Follow this guide.
Turn ON the car to ACC mode
Confirm that STATE glows in the right colour
Ensure that your NexCruise shows a single LED in the status bar, as per the following table:
Car
Colour of STATE led
Suzuki Brezza
Blue
Ciaz, Swift, Ertiga
Magenta
Nexon EV
Yellow
Tigor EV
Orange
BYD E6
Violet
It should NOT be showing any error pattern, i.e. first LED=red and all other LEDs glowing in some form.
For more details on error patterns, read this article.
Confirm that there is no Check-Engine light on the Car's dashboard
The "Check Engine" light should not have appeared on the dashboard.
If isn't not there - Congratulations! Its going great!
If its there, follow this article.
Start the car's engine
Ensure that the STATE led changes to white, and stays white when you put the car in Drive/Gear and apply acceleration.
Also ensure that the engine responds to accelerator pedal input before you start moving.
During drive
Now, start driving your car with NexCruise installed, ensure that the STATE led on the Lightbar stays glowing in white colour when you start moving.
Ensure that it is driving normally
It should be driving like it did before you installed the NexCruise. No surprises. Drive it for a while till you're sure of this.
Engage Cruise at a slow speed
Once you've ensured the above, move to a relatively open road and press the centre cruise button. The green "Cruise" LED should glow on the lightbar and the car should start cruising at the current speed. Take your foot off the accelerator pedal and confirm that cruise is working.
Test dial driving, cruise resume etc and ensure that other functions are also working like intended.
After drive
Once you come to a stop, turn off-on your car a couple times again without taking special care of anything, and verify that the NexCruise works perfectly each time. Engine light should not appear, and car should drive perfectly fine.
If everything works, congratulations! Things seem perfectly alright, and your car is now officially powered by NexCruise! Go ahead and put that sticker on your car proudly proclaiming the same :)
    • What if you see Check Engine light on your Car
      Introduction Check engine light appears on your car's dashboard, and looks something like this: A healthy vehicle is not expected to show this light. If this has appeared during/after your installation of NexCruise, follow these steps to fix it. ...
    • Checking firmware version of NexCruise
      Introduction The software that powers your NexCruise is called "Firmware", which gets updated from time-to-time via the so-called OTA (over-the-air) updates. OTA updates bring new features, enhancements, and bugfixes to your NexCruise. The Version ...
    • NexCruise and Driving safety
      When you're convinced that NexCruise gives a lot of value and benefits, safety is the next logical query that comes to mind. This article talks about all the mechanisms that are built into NexCruise to ensure failsafe behaviour. The best things first ...
    • Error codes in NexCruise
      Introduction If NexCruise encounters an error, like a loose cable etc, it indicates the same on the light bar in a colour-coded fashion. NexCruise is programmed to err in side of safety. That is, if in doubt, indicate an error. So, sometimes it might ...
    • Connecting NexCruise to your car
      This is an article in series with the Installation Process of NexCruise. Be sure to start from the start! First article:<TBD>Previous article: <TBD> Next article: <TBD> NexCruise Installation We will remove the cable from the car's pedal (by pressing ...
